Albertm
Member
I did a midi peice in Sonar 5. At end of piece it trails off nicely. When I change from midi to audio with Bounce to Tracks command so I can burn to CD, the end of song trail is gone. It just cuts off. I added reverb to overall track. It does work but I wanted track dry. Also tried just exporting midi tracks as WAVE. (I read once that you need not convert soft synth tracks to audio, I forget where in these pages) But there was no sound. Didnt seem to work.
I even Set the Options/Audio/Adnaced setting to "Play effect Tails" (But it seems not to make a difference, probably becuase there are no effects)
Any ideas why the trail cuts off when converting midi to audio , any trick I can use to keep trail even if dry? Hope this made sense. Thanks
