A
AlfredB
Hi there,
if you - just like I did some days ago - have problems using your middle-of-the-road computer for home recording, check out the following links:
A
Start out with the following Tips (win XP) - which make a lot of sense. They basically turn off all the XP nonsense that slow your system down
http://www.musicxp.net/tuning_tips.php
B
make sure DMA (direct memory access) of your HDD is enabled ... win XP DISables them permanently if there was a problem in the past- you need to switch it back manually. Details find in the following link:
http://www.michna.com/kb/WxDMA.htm
C
your video-card is probably clogging up your PCI bus-throughput (video latency = probably set to 256). Set the latency of it at 96-128. Check your system with "Ulyses" and reduce the VIDEO latency using a program called "Dbldawg". Details on both prgrms find in the following link:
http://mark-knutson.com/t3/
Those 3 links helped me speed up my system quite a lot and get rid of 98% of all the crackles, hickups, etc...
Thx to manning1 and noisedude for a lot of good tips, too!
cheers
Alfred
ps: could somebody make this sticky for a while????
A
B
C
cheers
Alfred
