NL5
Unpossible!
That is one cool new feature!
That is all..........
Bass Master "K" said:How does it work? I kinda don't want to know because then I will want to upgrade to 3, but I'm really curious how it works.
Bass Master "K" said:So does it burn the effect to the audio then? Or is it like an insert where if later you don't like it you can take it out and choose something else?
That would be really cool if it is option #2...I have a TC electronic M300 that I use for verbs since I don't care too much for the verbs in the box. It would be sweet not to have to bounce tracks through the unit and rerecord them onto a seperate track where I always have to keep the original track around in case later on in the mix, the effect isn't sitting right.
yes, but what i'm saying is that I use a patch panel. So say I was using inputs 1&2 for return from my reverb unit. Then I decide I want to record some new vocals, so I unpatch the reverb and patch in my preamp. Now, it looks as if in order to record inputs 1&2 on cubase, I have to delete the external FX I setup for the reverb, and add vst inputs 1 back in again. Then when I'm done, in order to go back to using the reverb, I have to create the external fx all over again. Is there a way around this?
