SX, Halion and the busses in the track mixer
  • Thread starter Thread starter zardoz
Z
zardoz
I am using SX. I utilize the Halion for samples. In the track mixer each VST instrument has it's own track, nevertheless, each Halion I load has it's own track on the mixer, yes....and a number of busses shown directly next to the track. The buss number ONE always shows the volume...the others, nothing.
Now...I would like to use these busses to add seperate effects to each program loaded that I am using on each Halion instrument.
For example. I use one Halion for percussion. Rather than put the same effects on all the percussion instruments loaded into that particular Halion there must be a way to have each loaded into a separate bus where I can then apply a different effect.
Only other alternative is to use more Halions as VST instruments...something I want to avoid like the plague seeing as it uses up SO much CPU each VST instrument.
So....how do I assign separate programs loaded onto Halion to separate busses?????
I have not used halion, but every single VST that I've used (kontakt battery reason etc) have settings to create more busses.
The setting to choose how many busses from that instrument show up in the cubase mixer is never a setting in cubase, it is always in the preferences or other menu of the VST itself. Check out the options in halion...
