Switching drivers to record guitar on drums
  • Thread starter Thread starter asaga
A
asaga
I'm using reaper as my DAW and I use Superior Drummer under ASIO4ALLv2. Once the drums are taking care of, I need to switch the driver to the M-AudioUSBAsio so that I can record my guitars. The issue is I can only hear the drums at a very low volume when I record the guitars (because of the m-audio driver). So do I have keep switching back and forth between drivers in order to record with the drums? I've been recording under the M-audio driver, then switching to the ASIO4ALL to hear it with the drums. Thank you - Jon
Sorry, I'm not too familiar with Reaper, but why are you using ASIO4ALL to run SD?? Can't you just run it within Reaper as a VSTi??
Why not just do like chili said and use one driver or the other. Your volume issue is most likely due to using 2 different drivers, or a gain stage error.
