G
gascap
Hi All,
Well, I'm a bit confused again....
Is there a big difference in whether I use wood or steel studs?
Steel is half the price and according to the SAE web site:
2 layers of 16mm (5/8") plasterboard each side of a staggered steel stud - w/ insulation has an STC of 58
Staggered (wood) stud wall construction with 2 layers of 16mm(5/8") Plasterboard on studs of 95x35mm (4 x 11/2") on a 120mm (4 3/4")common base - w/ insulation has an STC of 54.
Unless I'm mistaken by these numbers, steel performs equally to wood (or even slightly better.) Is there another acoustic factor I'm missing in comparing the two?
My budget would benefit from steel....or is this a 'given' that I've been missing 'til now?
Thanks!
Thanks!
