sdelsolray said:
Thanks Harvey. That helps explain things. I've noticed (at least with string instruments like the guitar) that the relative amplitude of the harmonics is lower than the fundamental. The 2nd harmonic (e.g., the first octave generated at the 12th fret of the string) is lower in volume than the full string fundamental. The 3rd harmonic (at the 7th fret) is even lower in volume, as is the 4th harmonic (at the 5th fret), etc.
Do you know if amplitude of the electronically produced even and odd order harmonics (relative to the amplitude of the fundamental) is the same as the fundamental or does it fall off like it does with string instruments in the real world?
Electronic distortion is a strange beast. When the signal to a tube exceeds the linear portion of the tube's amplification range, tubes tend to generate even order harmonics, generally a strong second and fourth. and yes, the levels tend to be much lower than the fundamental.
Most transistors have a lot of odd order harmonic stuff, often much higher in amplitude than the 2nd and 4th harmonics.
But transistors are a different animal entirely. When the input levels of a transistor are exceeded, it's kinda like running into a brick wall. When the input levels of a tube are exceeded, it's kinda like running into a wall of Jello.
With a tube, the distortion just keeps going up as you increase the input. With a transistor, the distortion stays low, right up to the point of clipping, then it goes up dramatically, almost straight up.
These explanations are gross generalities of course, but it does help explain a lot of what most people hear when distortion occurs. MosFET transistors, for example, tend to act more like tubes in the way they handle excess signal levels.
Whoops, I forgot to answer your question.
When you see THD (Total Harmonic Distortion) figures of maybe 5%, that means that the total of all the distortion components add up to about 5% of the fundamental signal's output.
So an amp putting out 100 Watts of a 1,000Hz note (with 5% THD) will have 5 watts of signal devoted to generating distortion products, like maybe 1.5 Watts of 2nd Harmonic Distortion (at 2,000Hz), 2 Watts of 3rd Harmonic Distortion (at 3,000Hz), 1/2 Watt of 4th Harmonic Distortion (at 4,000Hz), and 1 Watt of 5th Harmonic Distortion (at 5,000Hz). The amounts of each part of the THD distortion will change, depending on the design of the circuit.
