Chili
Site Moderator
I have an idea for the A/C. Build a vented box outside and mount the unit inside the box. Build a small chase up the outside wall to the A/C window, run flexible 4" pipe through it (cheap drainage pipe or even clothes dryer exhaust ducting should be fine) and turn the window space into an intake vent. Just try it to see how it works, whether you can get a remote to work with it, and what the sound is like. If you like the result then you can worry about making it pretty. Most of the A/C I've seen in studios involved remote units of some sort because of the noise.
That's not a bad idea. Eventually, I want to build a shed in the area behind the studio somewhere. Maybe I can incorporate the a/c in there somehow.
You've got to throw away the used Kleenex and rock-hard socks.![]()
I knew I was leaving myself vulnerable with that comment.
But quiet and cool.
