WelchRecording
I've had this computer for three years and done all kinds of modifications on it to make it the computer that I use now to operate a small family-run recording studio. Recently, however, it's started overheating and actually froze up during a recording session! It's also gradually started to run slower throughout the last several months and I need some advice on how to solve the situation.
I've checked the system errors and warnings, done all kinds of troubleshooting, and even bought an external USB 2TB drive to store my processed recordings on to increase the write speed on my existing IDE drive. None of this has solved the problem of it taking 10-15 seconds to start/stop recording in my DAW (Ableton 8), especially when I have up to 13 tracks active for recording drums. It will start recording as soon as I click it, but then the 10-15 seconds that follows the DAW completely freezes up while recording and I can't even stop it until a minute later no matter what happens. About a year ago I didn't have any of these issues... so here's my thoughts:
Perhaps my power supply just hasn't been putting out enough wattage. One of the LED lights on the front has stopped displaying, and I have about 3 extra fans installed in the computer that may take too much power. Also, I get fan speed warnings on my ASUS motherboard BIOS on startup. This would also be the reason that my heatsink/CPU go higher than 52 degrees and freeze up since it's not getting enough power.
Or, perhaps I just need a new heatsink. When my CPU overheats and freezes up, the heatsink is the only part of the computer that is hot (and it's reeeeally hot). This may either be cause it's not getting enough power or perhaps I just need to get a supercharged heatsink cooling system.
I'm running low on money and options, so I have one of the following options to try first:
1) New PSU
2) New Heatsink
3) New hard drive w/ faster write speeds to stop the delays on recording starts and stops.
(Or perhaps the starts/stops are caused by not having enough power to the MB?)
Please do tell me what you think! Here's the hardware that may be involved in the problem:
ASUS A8N-SLI Mobo
AMD Opteron 185 2.6GHz CPU (stock heatsink)
ATI Radeon HD 3870 GPU w/ a PCI cooling fan below it
2 PreSonus FireStudio Project Interfaces via PCIe FireWire 400
4GB Kingston DDR-400MHz RAM
1) New PSU
2) New Heatsink
ASUS A8N-SLI Mobo
