D
dankillmall
To Start with, I'm running Pro Tools 8 LE through a 003 rack on windows 7. My problem has only recently started occuring: basically, whenever i record anything the waveform looks fine, in time, etc. but when i hit stop, pro tools jumps the waveform back, as if it is compensating for the latency. The problem here is that Pro Tools is pulling it back extreme amounts, the last region i recorded was coming in at over 1400 samples earlier than was actually recorded. This problem only started when i upgraded to windows 7. I have tried changing my buffer settings and, well pretty much every setting in the playback engine menu, but there seems to be no change. Has anyone else had this problem? Does anyone know what might be causing this? Thanks in advance for any replies
