Storm-Related Roof Damage: Some Impairment Is Not Immediately Visible
  • Thread starter Thread starter johnsonron
J
johnsonron
Atlantic hurricanes and winter blizzards are common types of storms in Halifax, Canada. These weather events can occur about three to five times a year. On top of that, Halifax’s geographical position makes it more vulnerable to storms from June to November and again from December to March. Since almost every storm, minor or major, can cause some form of roof damage, homeowners often instinctively inspect their roofs afterward to ensure everything is safe. You may feel confident if the gutters and shingles still appear to be in place. However, roof damage is not always immediately visible from the outside. Please don't rely only on what you see. There may still be a risk of severe damage. The longer these issues are ignored, the more serious and expensive the damage can become.
The storm may have affected your roof's structure in ways that you may not immediately notice. Hidden damage can continue to worsen over months or even years without showing obvious warning signs. Eventually, these issues may appear as drafts in the attic, water spots on the ceiling, or even mould growth in certain areas of the home. That's why you should never take these problems lightly. You may not need emergency services, but you should definitely contact technicians who offer storm damage roof repair Halifax. Experienced roofers can detect hidden damage much more easily.
Underlayment​
This water-resistant barrier sits beneath the shingles and plays a critical role in protecting the roof from moisture intrusion. Roofers can inspect it carefully for signs of storm damage. Due to high winds, shingles may lift and fall back into place repeatedly, causing the underlayment to puncture or tear over time. Heavy rainfall can also degrade the material by forcing moisture into vulnerable areas beneath the roofing surface. This can severely compromise your roof's water-resistant layer. Surveys suggest that this type of storm-related damage is visible in only 15% of cases. If you notice water stains in the attic or musty smells on the upper floors within weeks or months after a storm, there may be reason to suspect an issue with the underlayment.
Flashing​
You must have seen metal strips installed around skylights, roof valleys, vents, and chimneys. These are called flashing, and they help direct water away from vulnerable areas of the roof. Due to high wind speeds during storms, flashing can curl, loosen, crack, or bend. Even the seal between the roofing material and the flashing may separate over time. Flying debris can dent or damage the metal surface, allowing water to intrude into your home.
Most weather-related water infiltration issues are linked to flashing failures in some form. However, this doesn't mean the flashing has to come completely loose to be a concern. Even small gaps or loose sections can allow moisture to enter hidden parts of the roofing system. You cannot afford to ignore these signs, as they can eventually expose the inside of the house to water intrusion and mould risks. This kind of damage may appear as water spots near roof valleys or around chimneys, rust on metal flashing, damp areas in the attic, and similar issues.
These are just a few examples of where the actual damage may be hidden after a storm. It is always better to let experienced professionals assess these vulnerable areas carefully. You may not be able to access those sections safely or fully understand the extent of the issue on your own. But they can be trusted to do their best. Check Artisanroofing.ca if you need guidance.
I hear you. But what I really want to know is what kind of microphone are you using right now? Which is really a statement rather than a question so I don't know why I used to question mark.
You need a mic which can stand up to blizzards, and water ingress during the storm season.
Only last night I watched a documentary about the damage caused by an out of control raging US river.
Entire buildings were washed away, and those still holding on had water 3 feet deep flowing through them.
Any mics stored below waist height would have been totally ruined. But then, if you stored them in a waterproof box,
the box may well get carried 5 miles down river.
I for sure will be checking Artisanroofing.ca to protect all my sensitive recording equipment.
I can state for a fact that a vintage 1950s Shure 55 with the 3 impedance switch and amphenol connector doesn't work too well after being submerged in a couple of feet of murky water for several hours . Anyone think that I can get warranty service on it? It's still sitting in a box downstairs.
A buddy lived several hundred feet from the beach north of Tampa. 3 to 4 ft of seawater didn't reach the roof, but it did quite a number on his Harley, stereo equipment, drums, clothes, furniture, TVs, and appliances. Surprisingly, he was able to dry out the drums and get almost all of them fixed up.
When a lazy river that is normally about 40-50 ft below the highway turns into a torrent and washes away the side of that highway, there's not much you can do about it. I used to drive this stretch every month. Very picturesque on a normal day. Mother nature doesn't give a diddly squat about anything mankind builds.
