gcapel said:
			if your using condenser mics, just make sure that the two mics are further apart than the distance from the mics and the source (acoustic guitar). Thus prevents phase cancelation.
Please correct me If this is a false statement.
Phase issue: courtesy of Klaus Heyne
This is going to be a long answer and still will only scratch the surface,so I'll give your the simple answer right at the beginning:
The polarity of mics is a develish problem to troubleshoot without a phase clicker.
Because mics are at the beginning of the recording chain, where, unlike with processing equipment, the "input" is an acoustic, rather than electric impulse, there needs to be a universal agreement, what exactly "in phase" / correct polarity means.
Fortunately, the Europeans did already fix a reference in the 1950s which has been gradually adopted throughout the world through the decades, to the point that today all mics manufactured are identical in polarity.
Polarity of a mic is defined as:
A positive acoustic wave at the front of the diaphragm of the mic shall produce a positive sine wave-half measured at pin #2 of the XLR.
(A positive acoustic wave is to be understood as the compression, not expansion, half of the cycle of air molecules wavering back and forth, and creating high or low air pressure at the front of the diaphragm.)
Trouble shooting and solution for your mics: Buy or borrow a phase checker (no studio should be without one!)
The checker consists of two units, the size of an MXR stomp box, a sender which pulses DC acoustically or electrically, and a receiver connected to the output of the device, which shows through a green or red LED whether you are polarity correct or have any polarity reversals between input and output.
These checkers are indispensable in all kind of applications. How often have they helped me find polarity reversals in car stereos, multi-million dollar recording studios, professional speaker cabinets, etc!
If you have good ears, and if you know the absolute polarity of your head phones, your cables, your mic pre and the polarity of a reference mic, you can identify the polarity of you mic under test by humming low notes into the mic (Polish Polarity Tester):
In addition to receiving the audio of your voice through the mic/headphone, you will always receive the same audio directly via your jaw bone into your ears.
If you set the listening level of the head phones about equal with the audio your ears receive directly from your voice cords, via jaw bone, you will hear if you have a polarity reversal somewhere in the mic/cable/power supply, because you will hear a drop out of low frequencies- the same audio which your ear receives from two different sources is out of phase from one source (the electric one). Adding both sources at your ear, with one source polarity reversed cancels long wave lengths (low frequencies).
If all this sounds too complicated, buy a phase checker.
