Z
zander91
Hey guys, wondering if i could get a little help, I have a presonus audiobox usb which is connected to a powered usb hub. The problem i'm having is there is a lot of static noise coming from the box, every time i arm a track to record with nothing plugged into the audio interface there is noise, which is sitting at about -45db, i've done everything i can to stop this i.e change the usb cable, re installer the drivers, clean the box, run the audio box through various usb ports and i'm still getting the same static noise. The quick fix solution is the gate the track but to be honest i want everything to work as it should. If this means i have to buy a new interface then so be but I want to know if there is a fix before i do this.
shed-studios
Get Yourself Heard!
shed-studios
Get Yourself Heard!
