Hey,
I'll just confirm all you deciding to go with the firepod. I've owned one for a couple months. I pretty much decided that nothing would come close to it in terms of available channels/preamps/portability/etc. It was the best bang for the buck I could find. After having it in my "studio" for a while, my thoughts are most definately confirmed. This thing has worked flawlessly ever since I turned it on.
I used to have a delta44 card and I used a dmp-3 for pre's, both of which are highly praised in this forum. Though I liked that set-up, the firepod is noticeably better. I don't know if it's the quality of the pre-amps in the firepod over the dmp3, or the quality of the converters in the firepod over the delta44, but the firepod has much more presence, depth, clarity, and on and on. Basically, it just sounds better. The unit has a function that mixes the level of the playback signal and the headphone out signal, making tracking extremely easy - it's a very well thought out unit.
The software you get with it is good, and you eliminate the need for a mixer, outboard mic pre's, heaphone amp, and a tangle of cables behind your desk. Can you tell I love this thing?
Click here:
http://www.feelslikefridaymusic.com/music.htm and listen to either "Something Better" or "The Way It Has To Be" (the way it has to be is probably a better recording) to the firepod in action. Compare to the other 3 songs below those 2 - they were done with the delta44/dmp3 set-up. See if you can hear the difference like I did.
