speaker or instrument cable (line level, unbalanced)
  • Thread starter Thread starter notbradsohner
N
notbradsohner
Compression Addict
ok, so, i am going from my dmp3 preamp to my mixer, via the 1/4 inch outputs. So are these line level, or unbalanced, and what kind of cable do i use. speaker or instrument.
what are some other exemples of line level sources, and what are some unbalanced and balanced things.
ahhhh im so confused
Unbalanced - 1/4" TS (Tip, Sleeve) Typically line level
Balanced - 1/4" TRS (Tip, Ring, Sleeve) Typically line level
XLR is balanced except the pins represent the TR & S, and is typically mic level
Speaker cable is a whole other game - Non-shielded, speaker level (signal that would roast many non-protected circuits). Typically, "Speak-On" (NL2, NL4), 1/4" TS, banana plug or bare wire.
Basically, you want TRS 1/4" unless your mixer doesn't support it.
John Scrip - www.massivemastering.com
Also note that standard instrument cable (e.g., guitar cable) is not a TRS cable.
Just to amplify (:D I couldn't resist:D ) on the Massive answer, instrument level is much lower than line level (and a much higher impedence too).
