G
gdgross
I posted this in the 'newbies' forum, but thought I'd go for a re-post here, too.
Hi folks, I am new to the forum. I posted the following on a couple of guitar sites, but thought there might be some better advice here, too.
I'm planning on converting a room in my home to a recording/mixing/rehearsal room. It'll be used for electric bands as well as acoustic & classical recording/rehearsal to give you some idea of volume. There are three exterior 2x4 walls and one shared wall with the garage. The room is 10x14 with 8' ceilings and a concrete slab floor. I want to maximize every sqaure inch of floorspace, so a room within a room is pretty much out.
I had planned on pulling down the interior drywall from the walls and adding rockwool insulation, (the walls currently have no insulation whatsoever) then doing a drywall/sheetmetal/drywall sandwich on top. But a friend recently suggested to instead fill the walls with sand.
Sonically, would sand be better than fiberglass or rockwool insulation in terms of isolation? There isn't as much trapped air, but it's a lot more dense.
Practically, I am worried about the weight of the sand on the outside stucco. (On the inside I could use 3/4" plywood underneath the drywall for extra strength.) I'm also worried about keeping moisture out and what happens if it gets in. I can run all kinds of extra counduit and junction boxes before I close up the walls, so I won't have to cut into them in the future and have sand spill all over the place.
Your thoughts are much appreciated!
