T
tenkas
How can I configure if I want channel input or tape input monitoring, do I have to open the thing up?
tenkas said:How can I configure if I want channel input or tape input monitoring, do I have to open the thing up?
Ford Van said:Yeah, there is a jumper inside that is "global" (it effects all channels).
You could actually wire it to have an external switch.
Massive Master said:I had to have Soundcraft fax me the instructions to solder an 8" wire in each strip. Must've been a *much* older model.
I have the board John is talking about. The wire was to make the meters read post-fader. The stock jumper will switch the meter between channel input or tape input. We thought that was stupid, so we did the mod.Massive Master said:Switch? It was a *permanent* swap to post-fader. No switches, no jumpers. Not available on that version.
tenkas said:Ok thanks... I will have a look at the inside of the meterbridge
Yup, it's on the channel strips inside the mixer.tenkas said:Ok thanks... I will have a look at the inside of the meterbridge
Mine is a '97 as well.Ford Van said:I guess I remembered it wrong. I bought an original version of the console and talked to Soundcraft about the mod. But hell, that was in 1997, I could really be remembering stuff wrong!
