Soundcraft 600 Overhaul
  • Thread starter Thread starter pelagos
P
pelagos
Hi there
I have a Soundcraft 600 to "restore".
Its is basically working but needs a very good clean (pots, faders etc), and I would probably look to do some caps later if required.
I started by cleaning a couple of the input modules, the master module and 2 groups to get some signal through and see what the signal and noise level was like.
A couple of things I immediately noticed that any advice on were to start to 'troubleshoot' would be greatly appreciated.
The noise/hiss from the 'Control Room' outs and also the 'Studio' outs is quite bad - With no signal being played and just turning the volume up / down the hiss / noise is really bad - its the same in the Headphones.
Its also bad from the Group Outs
I run signal through 2 input modules (line level input) and then bussed to Group 1-2 and then to Pro Tools (via G/Outs into Focusrite Saffire interface). Sounds good but the hiss / noise is very bad when nothing is playing - it goes up and down when pushing the group faders up and down
But when I record a signal from the input channels line out (direct out - bypassing the master and group modules) to Pro Tools there is practically no noise at all.
So I assume the issue is with the master module and/or group modules or somewhere in between the input module and these?
Maybe the ribbon cable?? I have read that these can be problematic?
Hope this makes sense and any advise on where to start so I don't blindly go off on the wrong path would be great.
Thanks
pelagos
After a good clean the hiss / noise is greatly reduced.
I have an issue now I can resolve
Group 1 is very low in volume compared to other group channels
What I have tried:
Bussing different input channels to Group 1 (same issue so I don't think its to do with the input channels) - If I pan between Grp 1 and 2 on the same input channel the level goes up to normal for Group 2 (right) and back down low for Group 1 (left). This happens on all input channels.
Direct / Line outs from above test Input channels register good level
Swapping out different Group channels and setting the jumper to "1" to make it the Group 1 channel (same issue - Low volume - so I don't think it is related to a particular Group module strip)
Used different output connectors for Groups 1
The Tape In into Group 1 channel registers good level
Made new ribbon cable for Groups - same issue - although may have helped reduce the noise a bit.
If you really turn the volume up on the input channel you can get decent level to Group 1 but you have to really push it - Not sure what this points to
The above makes me think its in the Master Module but I am not sure were to start. I have tried to follow the circuit diagrams etc but get a bit confused and to me it does not look like there is any circuitry specific to Group 1 on the Master Module?? Although I am probably wrong...
Any advice on were to start would be great
Thanks
