R
rscottdrysdale
i just picked up one of these for FREE. always wanted a reel to reel. i've been a DAT-head for a while now (3 TCD-D3's (one is 17 years old!), 1 PCM-R300, and two DDS drives with audio firmware
the thing works - i'm now listening to a 7.5IPS recording i just made from vinyl
but i have to run the machine in 4-track mode and avoid track #2.
channel 2 is busted:
- playback: with a tape with known signal on track 2, there's no audio output and no meter movement.
- recording: no meter movement, and nothing recorded to the track (it does erase).
by "channel 2", i mean channel 2 in 4-track mode. in 2-tracks-per-side (stereo, flip tape over) mode, that's the right channel.
i tried squirting contact cleaner into the big long play/record switches and the switches on the little board that are operated by a cam on the tape speed switch. worked 'em for a bit, but nothing.
the bummer is it came with a box full of tapes (home made) of 60's and 70's stuff. but to listen to them, i'll have to play them backwards to get both L & R, record to DAT, convert DAT to a .wav file, and reverse the .wav file. whee! apparently the failure occurred while the guy still used it, because i came across a stereo tape of dark side of the moon using only channels 3 & 4 (same as my test recording).
i'm planning on finding a service manual. but in the mean time, anyone have suggestions on where to look? from my experience with 2-head cassette decks, it sounds like the channel 2 amp is dead - most 2-head designs use the same amp for play and record, switching in/out direction and EQ circuitry for play vs record.
i have a tektronix 475 scope with DM44 (the DM44 only shows odd values in the 10s digit - needs an IC made of unobtainium), so i can poke around - i just need to know where.
the only other problem i see (hear?) is mechanical rattling in 7.5IPS mode. probably belts or lack of lube on a pulley shaft.
.the thing works - i'm now listening to a 7.5IPS recording i just made from vinyl
but i have to run the machine in 4-track mode and avoid track #2.channel 2 is busted:
