R
Radovic
Howdy,
I'm using Sonar with a RME HDSP 9652 and was wondering if I always had to use the stereo channel configuration where Sonar channels are alocated to RME via channel pairs, 1+2, 3+4, etc?
The "HDSP ADAT1 OUT (1+2)(1)" could be configured such that only a single HDSP ADAT-channel is associated with each ADAT instance? It seems as though only stereo pairs are accepted using the HDSP; (1+2), (3+4) etc, of each ADAT port. I would prefer to only use "HDSP ADAT1 (1) (1), HDSP ADAT1 (2) (1), etc. Single channel use with a one-to-one relation instead of 2-to-one.
I'm currently using Sonar 2.1 and will continue to read the audio applications section under '\rmeaudio.web\english\techinfo\conf' but wanted to run this past this forum in case I am looking for something that may not be possible and will always need to select a stereo 2-channel configuration and set a (1-L), (2-R) , (3-L), (4-R), ... etc scenario in my mix input/send. Please ask questions if this sounds confusing.
Thanks for reading and if you think I should share this with another thread please advise,
Radovic
Radovic
