N
neon glow
I wasn't sure which forum it fits, cakewalk or cubase, since the host is Sonar 3, but the problem is with Hypersonic from Steinberg. After all I think this one fits better.
I add Hypersonic synth to my project. I create few midi inputs, each for specific midi channel in Hypersonic. (I used up channels 1 - 6). Now, i have to assign a track in Sonar, which is going to be an output from Hypersonic's out. I made only one ouput, for main out. So different channels of midi go into Hypersonic, and hypersonic playes them all out through the main out, using instruments that I assigned to the channels in Hypersonic. Everything's ok.. But when I recorded some midi music on channels 4, 5 or 6 (i'm not sure), the volume of all the channels started to go crazy. You know, there are two volumes that you can change in Sonar. The topper one goes up to 127 (i'm talking about midi track). The bottom one goes really high up. So, whenever I change the top one, the volume of the track changes appropriately. When I change the bottom volume (of those midi tracks, which go to channels 5 and 6 in Hypersonic), for some reason it affects the volume of all tracks that go to Hypersonic, and the volume suddenly becomes very quiet for some of the tracks. It's a whole mess up, which makes me feel very sad and lonely.
Anyway. I tried to reassign the recordings of 5th and 6th channel to channels 7 and 8. It still did affect the volume of the rest of the tracks. What the hell is going on?
I hope i described the problem clearly. If not, ask me, as I really need it solved. Can't continue working with a very nice piece.
Anyway. I tried to reassign the recordings of 5th and 6th channel to channels 7 and 8. It still did affect the volume of the rest of the tracks. What the hell is going on?I hope i described the problem clearly. If not, ask me, as I really need it solved. Can't continue working with a very nice piece.
I'm not sure why, I re-checked the usb dongle, sonar update, etc etc. Whenever I insert it, Sonar crash. Other DXis run fine tought. So, I "borrow" his cd & install it @ home. Same thing... Sonar crash after I load Hypersonic. Hours of trial and error, nada...
