gullfo
sonar 4 - track folders, freeze, and surround. even if you output stereo, having everything pumping through the surround mix gives you an incredible amount of latitude in your mix. track folders really make thing much easier to organize/mute/archive. freeze is good on softsynth but I tend to bounce midi to audio anyways and then archive the synth - but for audio tracks where I think I have the effects set, the freeze option is great. the comp'ing layer display is great! having the ability to put takes side-by-side and manipulate them really speeds things up tremendously.
work flow is really good. surround is amazing. freeeze is very useful. there is also an "overview" of the mix so you can see where you are relative to everything + click to move there... lot's of little features like that make it a much better environment. and if you already own sonar and can upgrade to $179, definitely do it.
