C
CWMarketingGuy
Re: CW MarketingGuy...
Jaymz,
You have been able to do what you're requesting for years. There's an editing command called Interpolate that allows you to do search and replace editing of MIDI data.
You also could convert MIDI to shapes. That would change the MIDI controller data found in the Piano Roll view into Envelopes. You copuld then right click on the envelope and assign it to a different MIDI controller.
The biggest improvement to MIDI in SONAR 3 is the improved MIDI routing. Your inputs are not merged anymore which means you can have multiple controllers playing multiple synths at the same time. You can also layer soft synths and play them from one controller.
MIDI groove clips are also new. Think "ACID" for MIDI. You can roll out MIDI loops just like acid loops now.
James Argo said:Kewl...
The most reason I stick with SONAR (cakewalk) is because it handles MIDI alot better than others!!! That's realy important for us. Then, how about an improvement in MIDI section? I mean, not DXi thingee... it's about how SONAR3 handles MIDI data? So far I've seen only improvement on MIDI sync is mentioned... how about transforming particular MIDI controller data to some other number ? (eg. turning all selected CC no. 7 to 11, etc...) Can you explain it ? Thank's !!!
Jaymz
Jaymz,
