D
dumass
hey, i use a carvin mts 3200, and i would like to buy a pedal that would be good for solo boosts and soloing. i can then use my amp only for rhythm parts where less gain is needed. i was considering the boss ds-1...any opinions?
i also have a stupid question...while i do use the solo boost, would i have my amp on the clean or the distortion channel? i've never used any pedals before, so i'm unfamiliar with this.
also, my footswitch for the amp has a switch for reverb/effects. if i leave the pedal turned on, and then hit the effects switch, will it turn on and off with every hit? (given that i put the ds-1 through my effects loop...or should i run it through the guitar to the amp...?)
and someone else may be able to tell you exactly what he used.
