Phantom power is essentially a power source that gets sent to the microphone through the mic cable. The specific reason why condensers require power gets more complex than I care to delve into at the moment.
So, your options...
The Soundblaster Audix sound card doesn't have built-in phantom power. I don't even know if you can connect a mic (aside from a PC mic) to it and get a useable signal. You would essentially need a mic preamp or an interface, which I will explain now
Mic preamp: this is a stand-alone unit that you plug the microphone into, which (if the unit offers it), powers the mic, and then allows you to turn up the gain to the point that what is getting played into the microphone comes out at line-level. Line-level is what your Audix sound card accepts, so you would need the mic preamp to do all these things. An inexpensive but very good model is the M-Audio DMP-3.
The only problem with this is that Soundblaster cards aren't designed for audio recording, and as such, the other option makes more sense, and is in about the same budget range.
The audio recording interface. This is a device that connects to your computer via USB or firewire (or moreso, back in the day, by PCI card, but you still see these around too). It allows you to plug various audio devices into it (be it mic, keyboard controller, etc), and then converts the analog signal to digital and passes it into the computer. It does this at a much higher quality than a Soundblaster card will. And since it offers the full package (mic preamp with phantom power, good analog-to-digital converters), it seems like the logical choice. The following is just one of many different interfaces that you can get, but its an inexpensive one that gets decent reviews:
http://www.musiciansfriend.com/product/Lexicon-Lambda-USB-Audio-Interface?sku=245506
Poke around the computer recording forum for more information on this, but hopefully it'll get you started. Feel free to ask more questions as they come!
