bennychico11 said:
well, technically speaking SMPTE is actually an association of engineers who create internationally recognized standards. It stands for the Society of Motion Picture and Television Engineers.
SMPTE time code is just that....time code and was developed by those guys who are a part of SMPTE.
Actually, the SMPTE adapted a time code that was developed at NASA. It has been streamlined into "Litzi" (LTC), "Vitzi" (VTC) and "Mitzi" (MTC). LTC is "Longitudinal" time code for straight audio, VTC is vertical interval time code for video, and MTC is midi time code. 30 fps with 100 subframes per frame gives an accuracy of 1/3000th of a second.
bennychico11 said:
Computers need the SMPTE code converted over to MTC (MIDI Time Code) in order to understand it.
It's the programmers and the software that needs it converted. The computer can handle it just fine if a programmer takes the time and trouble to write code for it. I have and still use a 1985
Atari 1040 STE that reads and writes true bit accurate binary smpte time code. This is an 8mhz processor with 4mb of ram and no hard drive. The smpte code is not interpreted or translated at all. My sequencer (Hybrid Arts SMPTE Track) reads and writes smpte using machine code in the hard-wired Atari os. I used to do exactly what brendandwyer describes below......
brendandwyer said:
the way that it works (this is the non tech but works version) is that a device that generates SMPTE time code outputs it via 1/4" jacks to a recorder. In my case, i use a Mackie SDR2496 to generate time code and i record it onto track 8 of my Tasam 1/2" 8 track. Then, i put the Mackie into slave mode and set it to chase time code. It waits for me to press play on the 8 track, it *listens for the time code, and after a short 2-3 sec delay it locks up with the code that is being played into it. In that way, 7 tracks on the tape machine and 24 tracks on the Mackie are playing and recording in sync. This is one of the number of uses of SMPTE time code.
I did the exact same thing with my Atari, the Hybrid Arts sequencer, and a Teac TSR-8. SMPTE time code to track 8, then synch the Atari to the tape. I replaced the TSR-8 with a Tascam 2488, and now I do the exact same thing on that machine......SMPTE time code to track 1, then pipe it back to the Atari to drive the sequencer. I do this because the Hybrid Arts sequencer is so old it doesn't know what MTC is.....but I kept using it because it is otherwise a very powerful and friendly sequencer. It only recognizes clock and song pointer, but it runs on true binary smpte time code. I can random locate my 2488 to any point in the song, hit play, and the Atari will synch up perfectly in a second or two. Works great! And it has a midi-plexer that gives me 4 banks of 16 midi channels each......1-16 on banks A-D, or 64 midi channels. It controls my drum machine, my synths, my guitar amp, all my fx units, and the 2488 levels and mixer. The only thing it cant control is the 2488 transport.
