grimtraveller
If only for a moment.....
You get bigger as you go {no one told me - I just know}
The other thing about home recording ~ in much the same way that few turn out superlative mixes on their first go, it's rare that gear is never upgraded so the idea of upgrading monitors somewhere down the line, far from being a waste of money to be avoided, is actually normal and very, very usual.
It's by no means unusual for experienced pros to see shortcomings in their work of yesteryear. Which tells me that we shouldn't underestimate the value of progression, which in turn can mean - start small and get bigger as you go.
While I understand and appreciate where you're coming from, I heartilly disagree. From the things people say on these forums, I would say that most people that are looking to start mixing are looking to start mixing. What's in reality more important is just getting a start somewhere. Regardless of the advice one gets regarding monitors, fact is no one hears through someone elses ears. So what X may think is a shitty set of monitors may turn out to be a goldmine for Y. No two 'studios' are set up the same and the mixer in question ultimately is the only one that's going to arrive at the final mix. So really, monitors are a gamble.I know it seems a little elitist to say "If those are your options, you're better off not getting anything at all". But depending on what you're looking to achieve, that is somewhat true. If you're fine with mediocre mixes then sure, go ahead with bad monitors. But if you think this is a hobby you're going to enjoy for a long time, why not save up and buy something you'll use for a long time, rather than keep buying and upgrading. At the end of the day, you'll waste more money doing the latter. You probably haven't tested out a lot of monitors, but once you do you'll realize how bad most small entry level monitors really sound. Not to say you can never get a good mix out of them. With a lot of practice you'll eventually learn your monitors, but it'll be a frustrating ride with lots of guess work involved.
). People here will tell you the behringer sucks, but I gotta say
