N
DJL said:Hey thanks Neil for quoting my post so Mark can see it.![]()
Scinx said:What did you do as far as the connector was concerned for the 666 Chessrock?
So first I yanked the thing where the pins stick out so it was even with the base of the microphone. That way you can fit a standard XLR mic cord on there. I had to switch the pin wires on the cable, though. I just played musical pins untill I got something that passed signal.
So I've got a special jerry-rigged cable now I use just for the 666.goldtop said:With regard to the ADK A-51 STD Type V, anybody used one? Would it compare to the C2000B in terms of quality, applications etc.
- but he won't feed you a line about how his products blow everything else away, he'll just give you some advice on whether it'll suit your applications.chessrock said:
You guys . . . Chessparov turned me on to the Electrovoice 666, as per some comments by Bob Ohlson at the Gearslutz forum. Anyway, I picked one up not long ago for around $100. Guys, this thing smokes. I'm considering selling every one of my mics and recording everything with it. Not really. But if I had a thousand bucks to spend on mics, I might consider getting 10 of 'em.
tdukex said:Chessrock, how do you like it on vox--male, female, low, high? What mics would you compare/contrast it with?
Big Kenny said:You should do yourself a great service and buy a sennheiser 421 (441 ifyou can afford it) It is great on everyhthing you mentioned and you will NEVER outgrow it
In HIs Name
BK
P.S. how do you guys get your words so big? that's cool, heh.heheh
chessrock said:I guess this would be pretty obvious, but I'd compare it with the RE-20. Very tight bass response. Very smooth highs -- almost ribbon-like. Kind of aggressive in the midrange like an sm57, but smoother and more professional like an RE-20 or an SM-7. What a fantastic midrange presence this thing has -- just very smooth and pleasing. I can already tell I'm going to like this on guitar amps.
