VOXVENDOR
rapper2001 said:
Sounds good but what effects did you use?????
Bit of EQ, compression and a Reverb with a bit of pre-delay on it.. Nothing too drastic.
Joe Bochek
jeap said:i am going to go out on a limb here and recommend that you get a condenser microphone. and get a gemini dj mixer.
http://www.8thstreet.com/product.asp?ProductCode=1542&Category=Microphones
crazydoc said:Here's the cord you need to go from the mic/transformer to the mixer.
http://www.radioshack.com/product.a..._name=CTLG_002_001_002_000&product_id=42-2378
Your clip sounded ok to me - I think you can get good results with what you have now - upgrade when you know what you need.
crazydoc said:How do you hook the cable to the mic? Doesn't the mic have a 3 prong connector on the end?
If it's a cable with an XLR plug on one end for the mic, and a 1/4" plug on the other for the mixer, that's probably the whole problem right there.
No jeap,jeap said:maybe harvey can tell us all about microphone impedance and why some mics have 1/4" plugs and some have xlr at both ends of the cable and why cant they be interchanged freely and where does time go!
jeap said:so the cables are interchangable????
With low impedance mics into low impedance mixers, yes, the cables are interchangable, as long as the pre doesn't care whether the signal is balanced (with an XLR or sometimes a 1/4" TRS plug) or unbalanced 1/4".
we can use the cable with the 1/4" plug with an sm57?
Into preamps that are designed to accept low impedance, "unbalanced" 1/4" mic level signals, yup, you betcha.
we can use xlr to xlr with our radio shack mics?
With R/S mics that have low impedance, balanced mic outputs on XLRs, into preamps that can accept low impedance, balanced signals thru XLRs, yup, you betcha.
and theres no probs?
With unbalanced signals, there's more chance of hum pickup and induced noise, slightly lower output, and you're limited to shorter cable runs (under 50 feet), but in most home studios, there won't be any problems.
why do ppls always recommend the transformer things as if you HAVE to have them to convert 1/4" to xlr and vice versa?
why?
Because a lot of "ppls" don't understand how this stuff really works. Some mixers and recorders are designed for use with high impedance sources.
To plug a low impedance mic into a high impedance input, you need to convert the mic's low impedance to high impedance with a transformer to get a proper transfer.
You read the mic specs to find out the mic's impedance; low impedance is usually any number under 1,000 ohms. High impedance is around 10,000 ohms or higher.
You also read the specs on your recorder and mixer. If it says low impedance input (and it's a 1/4" input jack), you don't need a transformer. In fact, a lo to hi transformer will seriously degrade the performance in that situation.
Understanding how the signal moves thru the various pieces of gear and "gain staging" (figuring out where to set the knobs for highest output, with the lowest noise and distortion) is one of the hardest concepts for new recordists to grasp. Set the levels too low, and you're giving noise a free ride; set the level too high and you distort on the loud stuff and bring up room noise on the soft stuff. Setting the gain too high too early in the chain can cause distortion in all the rest of the gain stages. Most of the "my sound is crap and I'm not pegging the meters" problems happen because the first stage amplification is too high, and turning the signal down later won't reduce the distortion.
