jpmorris
Tape Wolf
A lot of the issues with making the DAW slave are going to depend on the setup and also the architecture of the DSP kernel. At the end of the day, changing a pointer in memory is going to take less time to achieve than varying the speed of a capstan attached to a heavy, belt-driven flywheel.
Changing things DSP-side is going to disrupt things with regards to the wordclock, but that should be a momentary glitch which probably isn't going to be noticeable. If it's something that persists from thereon, I'd say there's a design flaw in the audio kernel (like SONAR v1, which was wholly useless for any kind of sync).
Another factor is whether the DAW is trying to maintain sync with other digital devices as well. If you're doing a three-way lock between the tape deck and two digital devices which are linked via a wordclock, then yes, it's going to be messy.
For the simple case of a DAW and a tape deck, jitter shouldn't be an issue since there's only one DSP clock involved.
At the end of the day, I figure you're going to have a choice between a momentary pitch shift on the tape side and a momentary blip on the digital side.
I haven't done any professional audio coding, but I have written a few simple mixing kernels in my time so I have some vague idea of what's liable to happen internally.
As for the ATS500, it doesn't have MIDI. You should still be able to use it to sync with a DAW, though. You'll just have to stripe one of the DAW tracks and send that to ATS500 to do a code-only lock.
