jortiz
I've lurking for a while on this site. This is my first post. I've actually asked "Sweetbeats" a bunch of questions by PM since I got a Tascam 520 recently without the PS cable. I'm starting to have an issue with the 520 now that I haven't been able to figure out yet although I'm thinking I'm needing to get it serviced. Anyways, here is the issue.....when powering up the board (it's happened twice now) The meters are slamming and all I get is squelching/squealing sounds from the monitors. There is nothing engaged on the board, channels on, eq, trim, etc. The faders are all the way off, no input channels on. At times the meters will slam and then go down to nothing but the OL (overload) lights will come on and some will stay on and others will go off. I then turn the whole thing off and then try again. Like I said, this has only happened twice since I've had it for about 4-5 months. This morning is when it happened again. The other time I just unplugged it and waited and made sure nothing was going on with inputs, etc, and then it was back to normal until today. Is this board needing to be taken apart and looked at on the inside? What do I need to be looking for? The amp section? I know something sounds like it's going out but I'm not sure what to look for first. Any help would be appreciated. I'm sure sweet beats will chime in eventually. Thanks for any advice.
John
John
Everything else I've been able to move in the car or hand-carry. Not so with Matilda. It is either try to get it back in the horse trailer or get some 3/4" plywood sheets and keep laying them end-to-end-to-end making a firm rolling surface as we go sort of like how the Egyptians moved pyramid blocks (albeit rolling on logs...fortunately Matilda has some hurky casters)...thought about trying to pull it with the tractor but I know something bad would happen through the gravel. It'd be funny though...I could take a picture of the MM-1000 with the garden tractor pulling it and caption it "Portastudio".
