X
Xrod
Greetings! This is my first post here.
I recently added a new mic and channel strip and am having problems taming the volume levels. I have an AT 2035 with db cut engaged, into an ART TPSII preamp with output virtually off, into a Focusrite 2i4 interface, also virtually off in order to get a reasonable recording level.
It seems like using a channel strip/preamp into my interface is basically ganging two preamps in series. The super hot signal makes adjusting the gain level super sensitive. Is this normal? Am I getting the full benefit of the channel strip sound this way?
I have similar problems when recording guitar and bass, active or otherwise, and have to turn the output of the instrument way down when I prefer to drive the pickups at a higher level.
Thanks in advance for any insight you all may be able to provide.
