signal chain question
  • Thread starter Thread starter dzara 4
D
dzara 4
im brand new to this so i hope i make sense asking this question.
What arrangment in your opinion works best in regards to a signal
chain.
mike --- pre amp ----compressor--- eq's ---- workstation
or possibly
mike---- gate--- compressor --- pre amp --- eq --- workstation
or anything else you can think of.
would love some advice
thanks
Personally, I think it should go preamp > compressor > gate > microphone.
All the great hits of our time were secretly done that way. Try it.
I'd say mic->pre->workstation. The shorter the chain the better IMHO.
For recording:
mic - preamp - record.
Then if you need compression, do it on playback. My comp has a gate built in, so that is easy enough. I like to compress after eq, cuz eq tends to mess with levels. (unless it is an insert, many of which are pre-eq).
But if you must compress going in, I like to do mic - preamp - compress+gate - record. Try not to eq on the way in.
Gating while recording is very dangerous - you could render the whole session useless. Almost no reason to take that chance - you can always add in the gates at mixdown.
