shure prologue 16L condenser
  • Thread starter Thread starter hlblyhipy
H
hlblyhipy
I just bought a prologue 16l condenser mic anybody have any info on it there is a switch on it does it switch the polar pattern on it .thanx
Andrew
Shure Prologue 16L ...Sorry...
The switch on the side turns the microphone on and off. This only has one polar pattern. This mic has a AA battery inside.
Pros- You don't need phantom power for this mic. AND DON'T SEND PHANTOM POWER TO THE 16L, IT WILL KILL THE MIC !!!
Cons- It's not a true condenser microphone. It uses the little bit of voltage to couple a low voltage field to produce audio. This audio is sometimes colored by humidity and temperature. Normal condensers us 48volts to generate FET/transistor/tube/transformer preamplifier's in the mics. This produces better audio.
I purchased 2 of these very cheap (2 for $60) about 10 years ago. Have used them sometimes to use when I am recording outside and don't have phantom power. But there are other mics that will out preform these mics for a little bit more money.
Mike (Buffalo, N.Y.)
