B
Beck
Guest
From Gerald Gibson, Library of Congress 1996
If you locate vinegar syndrome in your collections remove the 'sick' objects and store them separately to prevent the contamination of other materials by acetic acid. To slow the on-set and/or the advancement of vinegar syndrome, the consensus is that all acetate based materials will eventually develop vinegar syndrome, but it can be delayed for literally hundreds of years if properly maintained - store the materials at temperatures below 40EF, and below 25% relative humidity (RH) (do not freeze tape, as some manufacturers used a lubricant which reportedly solidifies on the surface below 32EF). There is no known method of reversing vinegar syndrome once it begins. If found in time before the base shrinks too much, or is unable to support the oxide, or becomes too brittle- with any luck you should still be able to play and re-record the information.
