Well...my strobe is accurate to 0.1 cents. At +/- 0.2-0.3 cents...the strobe is moving noticeably up/down.
I'll tune up with the strobe...play for a bit...and then I can hear one string out just a hair.
I go back to the strobe, and sure enough, it's no longer stable, but starting to slowly drift up or down. When I apply an offset on the strobe in order to stabilize the movement and see how far off the tuning has gone...at times it doesn't take more than 0.2-0.3 cents of offset...so that tells me the tuning was out by 0.2-0.3 cents.
Honestly...it's not that hard to hear it
when you are playing against another instrument that IS in perfect tune.
Heck...if I just tune up a guitar by itself, I can't hear if it's off by 0.2-0.3 cents...but against
another instrument, it's actually pretty easy for me to hear even that small a difference.
It's not so much about hearing it way out of tune...rather there is this slight dissonance between the two instruments even at 0.2-0.3 cents.
Sometimes at that small amount, I can't tell right away if it's 0.2-0.3 cents sharp or flat...but I can tell that it's NOT the same as the OTHER instrument.
Not to get back into that other thread...but that's why I still say for intonation, you need a strobe to get it perfect because your ear will have a hard time comparing the two notes since you play each note individually (harmonic or open, then presssed)...rather than playing/hearing them both simultaneously and being able to hear them against each other.
And even if you did, you might hear the 0.2-0.3 cents difference between them, but like I said, it's hard to always gauge if it's plus or minus 0.2 -.03 cents.
I don't have Superman ears
....it's just ear training and hearing one note played against another at the same time.
I believe that using the strobe for the last 8+ years has fine-tuned (excuse the pun) my hearing...and to tell the truth, sometimes it's actually a PITA, because I will stop many times to adjust the tuning for 0.2-0.3 cents because I can hear that it's not in-tune with the other instruments/tracks, or even other strings on a guitar.
There was someone who recently put up a song that they finished working on...and while a lot of folks made positive comments about the music...I found it odd that no one mentioned that the guitars were noticeably out of tune. Now...maybe everyone was being polite, and I certainly didn't want to toss out a monkey wrench either...
...but the guitars WERE out of tune.
That's what I was saying earlier...I'm amazed at how many people don't hear that they are out of tune.... *shrug*
