D
		Django2014
Hello,
I am looking for a light-weight software based midi-only sequencer, I don't need to record audio. I am no midi expert, so my requirements are not very precise, but let's give it a try.
- I intend mainly to record drums with it and an occasional background organ or a horn section. Audio I record on a recorder.
- I will use VST modules for drums and other instruments so it needs a VST interface
- It needs to be able to sync to an external clock (being a slave)
- It needs to be able to send out a midi clock signal to a device that translates this into audio. I will be using a pocket sequencer for this. I will record the midi clock onto a digital non-midi recorder. On playback, the recorder will send out the recorded signal, have the pocket sequencer translate it to a midi clock signal to which the sequencer will have to sync (hence the requirement to be able to run on a external clock)
- although I intend to keep it very basic (it will be used for making demo's and song sketches) some extra features like quantization would come in handy
There is an awful lot available, but most of it is packed with features I don't need. So if someone could point me to a lightweight sequencer that would be highly appreciated.
Cheers,
Django
Cheers,
Django
