selsong
Member
HI there
I wonder if anyone else has had this issue. Most of the time Cubase Elements 8 works just fine. But every now and then the following occurs:
If I select the scissor/cut tool and move the tool around, it leaves a trail of black numbers all over the screen. Normaly one would get a little white box which tells you your exact position. Eventually the screen gets so full of numbers, I have to close down and start again.
Also if I lengthen or shorten a part the same happens although sometime this tool does not leave the numbers behind, they disappear right away
Is this a Cubase issue or a video card issue?? I have checked and I have the current updated driver for my vid card.
I have never had this occur before in all the years I have used Cubase. I bought Elements 8 about three weeks ago and only since installing it has this begun to happen
Any suggestions would be really appreciated.
Many thanks
Many thanks
