H
			Jagular said:...but I have no idea what ASIO is and all that kind of stuff.
			 . This will probably never be relevant to me as I intend to upgrade my soundcard well before I upgrade to Sonar & XP. Limited funds you know
. This will probably never be relevant to me as I intend to upgrade my soundcard well before I upgrade to Sonar & XP. Limited funds you know  .
			James Argo said:
... Last night I downloaded the latest KX Driver, and install it.
Version: 5, 10, 00, 3528 - debug
Compiled: Dec 3 2002 00:50:27
Make a routing adjusment shown in the help files to achieve ASIO recording using SB Live! along with SONAR 2.2 update. IT WORKS GREAT BAYYYBEEEEHHH !!!! I got about 6.3 ms latency !!! That's correct... SIX POINT THREE ms. It was almost imposible to have this card working with latency under 10ms. But now I gotta tell you guys, based on true story experience... it screams outta the deep sea. My experiment was recording mono tracks, and record another tracks for total of four tracks running about about 70 measures and see if it slightly slided, but it's not... not at all. Curiously, I record few tracks of splited synth drums track. Soundfont to wave. After four tracks (this time all stereo), 120 measure, play 'em back together the MIDI & audio... the sound is veerrrrryyyy tight. Almost no gap. I zoom the wave block, just stay to the beat. This is soooo cooolll...
So, for you guys using the Green Submarine 2 along with SB Live! Follow moskus link..., download the latest KX driver, install it, read the routing help for ASIO recording, and update your Green Submarine to vers. 2.2. You'll erase the word "high latency" on your recording with SB Live! dictionary...
Ps. I didn't use input monitoring. Not yet. I'll give it a shoot latter...
Jaymz
			moskus said:What error-message? You've upgraded Sonar to version 2.2, right?
			Noodlehoss said:Hey All,
My first post here... This driver has raised my curiosity - maybe it can help me out... I've been playing around with a midi software called 'Guitar Synth' which allows you to plug a guitar into the card and trigger sounds on your computer with it. No extra midi pickups need to be attached to the instrument - all done with software. Here's the problem I have... there is a bit delay, a gap between when the string is played and when the note is sounded.
 Is this what you mean by 'high latentcy'? Do you think this new driver will help that? Are there other factors?
 But why don't you try and post here the result ? It could be good to know....
