Sansamp GT2 users...
  • Thread starter Thread starter cellardweller
I can see your point, just forget the name"SANS" and experiment.
chessrock said:
I'm still having trouble with the whole idea of using a SANS - amp ...
... with an amp.
Wouldn't that be like using Splenda with Sugar? Coffeemate with Cream? Wearing a patch while smoking?
I'm sorry. Don't mind me. Just carry on as if I weren't here.
Well Chessrock,
I can see your point, but just try plugging the Sans into an amp and see what it does.
Another aspect of these boxes is that they will work for anything, you can warm up your whole mix with them, or just certain elements like a bassdrum part.
many producers use the Sans for all kind of applications, and if you read the manual it will say it can be used for all kind of things. I really dig equipment like that, versatile and open for a lot of experimentation rather than tools which are just designed to do one thing.
Eddie
cellardweller said:
Amps-nothing I'm proud to mention. I have an ampeg VT120, and a crate 2x12 combo. Both are pretty crappy. Instead of buying a new amp this last time around, I bought a new guitar because all of those I owned were crappy too...
Did someone say something?
So you have crappy gear ?:D :eek:
Okay, well to get a better idea of the tones you are after you need to tell what is missing from your amps. Lack of bottom end? Not enough highs or................? Or better: "What kind of tones do you like in general, and do you feel you cannot make with the gear you are using?"
The whole tonequest starts with knowing what you like, knowing the gear you have, and seeing options of how to combine certain pieces of gear to come up with new tones.
I am going go give you an example or a certain set-up and the kind of tones you can get with that. I am sure that your amps are far better that this little guy here: The Marshall MS-4, it is the microstack.
Now this amp will work on batteries, but it will work far better with a powersupply.
On its own, that is without anything plugged into the amp apart from the guitar, this amp sounds so so............................
Now hang on here is the setup:
Gtr.---->TubeScreamer--->EQ---->Sans GT2---->Amp.
Okay the Eq after the Tubescreamer is to tune the tones of the Tubescreamer, and the Sans is to funetune the whole patch. The results are fabulous, easy to create good midrange Marshall tones, Darktones? No problem! Perfer more midrange? Well that too can be arranged, more Bright Sir? Okay there it is.
Now this is just one option with a very little amp, and all these tones. I am sure you can do far better that that with the amps you have.
Start with a clean tone on your amp, just a general tone, not too much mid, highs and bass, as you will add all of that with the Sans. Then set up the distortion pedal how you like it, after that you tune it with the EQ, then you start working with the Sans, but just keep it clean.
You need to remember that with the above set-up there are 4 volume controls: one of the Tubescreamer, one of the EQ box, one of the Sans and finally your amp. All of them need to correspond to each other and not override each other. Heh it is not all that difficult man, just listen and tweak a little!
So am I suggestion you should get seperate distortion pedals, eq pedals etc.? Well no, that is all up to you. My guess is you have some pedals lying around anyway as most of us guitarist do. If you do not have any seperate pedals you may be able to borrow some of your friends, just to experiment before you decide for yourself what to get. Easy eh? I am sure you have some friends eh? :D
When you use an all-round overdrive pedal [ something like the boss one or of similar ilk] you can always make them sound more extreme by using an eq pedal, so really you have the best of both worlds. Also the Sans's drive knob will give your enough bottomend to make your overdrive[or distortion]pedal sound more extreme.
Oh and yes I plug this whole patch in the line-input eh? Nothing like plugging into the effects-loop or something of that kind. If you would go for that than you may as well plug the whole patch into the effectloop of your recorder and record the whole setup direct. Now that is also possible of course, but you will get very different tonal results. I believe your already do this anyway and are more interested in hearing about different applications eh?
Now you get experimenting Sir, and tell us what you have discovered. I just cannot believe that you cannot get any good tones with what you have there.
Pick-ups of the guitar? I use humbucks, single coils would ask a bit more volume, but would give pleasing results as well.
String gauges? Very important issue, but personal as well. I tend to use and o11 set, and for the last two bottom strings I use an 0.46 and an 0.56, as this will help you a lot with heavy riffs on the low E and A string. I tend not to tune down that much, but if you wish so you can and it will not muddy things up that much, you can even tune down as far as C or B and it will still work, may need to moderate a bit your attack but it is possible. :D :eek: :eek:
Pickingstyle? I tend to play hard, at moderate volumes, I like to feel the attack, but the volume does not need to be that loud as the sound comes from your fingers and hands.
Okay now that should do it Ryan, let us know how you are getting on with things and remember ...............all of this will come with TIME and EXPERIMENTION, not necesarrily more gear.
Eddie
Since you have not posted a reply yet I take that as you are busy in your cellar trying to find all these new tones :D :D
Eddie
cellardweller said:
Umm yeah, about that response. It was around 4 am, after going to bed too early (6 pm) and being awakened by my white trash neighbors around midnight.
Well, that and behringer pisses me off...Amps-nothing I'm proud to mention. I have an ampeg VT120, and a crate 2x12 combo. Both are pretty crappy. Instead of buying a new amp this last time around, I bought a new guitar because all of those I owned were crappy too...
which crate 2x12? I play a vintage club 50 and I love it. the solid state combos are pretty damn good too as far as solid state goes.
FALKEN~ GX212 maybe? I'll have to look later when I'm at home....
It's not on crates site anymore. It's not horrible... for a crate :D. I do use it, but have only tried recording with it very few times with little success.
I haven't played anything but my shitty acoustic all weekend, one of those weekends. The action on that P.O.S. is terrible!
There are a couple of interesting ideas there timmerman. I have only one distortion pedal remaining, a boss mt2, so I'll give that a try with the gt2 clean.
There is NO new gear in my forseeable future, as we are still paying off medical bills, and trying to save to buy a new/larger house. So I've gotta get by on what I already have for a while...
Thanks to all.
Thanks to all.
Dude, you want an old Digitech distortion pedal, and some cheap rippoff of a TubeScreamer? I got em if you want em....
Ed
Ed
Great offer Ed,
I wanted to say that Cellar could borrow some pedals of me, but since I am not very near him it is a bit difficult.
Tubescreamers are very open to "adapting your sound", they will give your amp a boost, can add some dirt if needed or add additional brightness to your amp.
One reason for the hype around the tubescreamer is that it is a kind of pedal which does not alter your amp-or guitarsound much. There are many different brands which do "tubesceamerlike" pedals:
Ibanez: the TS 808, the TS9 and there is a turbo version of the TS9 as well. Ibanez is a little expansive compared to some other brands.
Boss: the SD1 [a lot cheaper that the Ibanez pedals, works on a different principal----linear distortion-----but to the ear sounds very similar as the Ibanez pedals, the Bluesdriver [BD2???] now this one has a lot more gain than the SD1, then there is Boss's overdrive one OD 3, again this one has a lot more gain than the SD1 or any of the Ibanez pedals.
All of the above models/brands are just a few examples and there are tons more of them, and no I do not say this for you to go out and buy...............it is just some info for things you may want to try for future.
You know that little Marshall I mentioned before? the MS4, again they are very cheap, and I just used them as and example, but because they are very cheap it may be tempting to try something like this. Again...............not saying: "Go out and buy...........because it is the very best" No, just some ideas.
Right on dude, enjoy the tonequest search.
Eddie
That's a whole lot of pedals that I know nothing about!
You know, I miss the days when I was happy with the half-assed distortion I got from my Carvin head. Not sure if I was just easier to please back then, or if it really had even 'half-assed' distortion. Of course, back then i didn't even care if my guitar was intoned! As often as not, it was probably out of tune as well....
"Simpler" times.
Thanks again for all the info timmerman, and dogman for your generosity which I might just have to take you up on :D
I'll get back with you after I wrastle with this Schecters intonation some more, tonight.
MT 2 and Sans is good to
Tried the Boss MT2 with the Sans and the Sans adds in this case also a lot of warmth to your sound.
The MT2 will not do the clean boost as the pedal cannot get clean. You may need to be careful with the distortionbutton on the pedal as the MT2 can be quite an extreme pedal. It is modeled with a modded Marshall JMC 800 in mind.
You may feel the pedal will sound fine on its own, yes that is true, but adding the Sans is adding some warmth to your whole signal and that can be addictive in terms of sound :D
Eddie
Cellardweller, try running the GT2 into the return on your effects loop only...
It is a preamp, and this will allow you to bypass the preamp in your amplifier, and use the power amp for the GT2.
i've sold my new Behringer GDI21 (less than a month old) and bought a used SansAmp GT2... but it doesn't come with the manual. so, do you have any idea where can i download the manual? thanx!
Yep yep, forgot about that one!
The actual manual is not very extensive anyway.
This was kinda useful though...
Place the following effects BEFORE the GT2: Compression, Wah-Wah, Envelope follower
Place the following effects AFTER the GT2:EQ, reverb, Delay, Chorus, Pitch shifter
I think that additional distortion/overdrive should also be put BEFORE the GT2.
