Ok I'm only familiar with analog mixing and working with stereo wav files. I've always used a Mic > Mixer > Soundcard, with the odd bit of hardware to clean the signal up.
Now today my friend brought his new gear over for me to test for him and show him how to use it, but I found myself having to learn a few new things myself.
1. The Focusrite Saffire 6 USB obviously just plugs in via USB so is a digital signal, which only records a single channel? Is that normal? Obviously with my analog set up I use dual RCA's for each channel left/right, but with USB it's a single line and I only got the left channel recording and playing back.
I configured my software to playback mono instead of stereo to fix that, but should it record the right channel also?
2. It does have an option to use dual RCA's for a left/right stereo input, but that defeats the reason he bought it, as he uses his laptop and not a pro soundcard like myself. So he could rig it up, but he'd be back to needing a soundcard or a mixer and the purpose of this unit is to eliminate the need.
3. Finally I also found the signal to sound a little strange, slighty echoy on his vocals. I'm guessing this is because his interface is technically a soundcard/preamp and I'm used to recording through a mixer, thus pre-setting the EQ to sound clean. Is that right or could it be linked to the fact the right channel doesn't record?
Hope you can help me, I'm new to these pre-amp interfaces
