NL5
Unpossible!
I don't think that's right about the phase thing. The out-of phase problem isn't directional; it's distance based. The sound waves have to hit the mics at exactly the right time where one is in a peak and the other is in a valley. A speaker is omnidirectional, so it doesn't matter if both mics are in front or in back, top or bottom, etc., or one one each. If they happen to be at the right distance where the mics pickup the soundwaves at the opposite end of the waveform, they'll be out of phase.
At least that's the way I've understood it.
But if I'm not mistaken (and believe me--I am mistaken a lot) in this case it has to do with a push/pull issue (I'm sure there's a better term!). Since the speaker is actually moving back and forth, when you mic it front and back (as opposed to two in the front but at varying distances) one side's pulling air while the other is pushing.
This may be completely off base, but I believe it's the same logic behind flipping the phase on one mic if you mic the top and bottom of a snare. FWIW--I don't mic the back of my amp, but I do mic the top & bottom on snare, and flipping the phase on one works for me there.
It's a combination of direction and distance. If both mikes are the same distance from the speaker, but pointed toward/away from each other, then you'll probably want to flip the polarity on one of them because as the speaker pushes air toward one mike, it's pulling it away from the other (air isn't actually traveling, but that's another discussion). If the distances are different as well, then this throws every thing out of perspective because now the compression/rarefaction of air is reaching the mikes at different times. In this case, there will ALWAYS be phase cancellations and summations, so your task is to make them work with each other and sound pleasant. Inverting polarity may or may not help the sound.
Speakers are NOT omnidirectional.
As quoted above, different sides of the speaker will be operating as polarity reversed. If it was possible to get the mics perfectly in phase as well, and the speaker was omnidirectional, the resulting combination of the two mics would be a null. No sound. Of course, the sound radiating behind the speaker will only be the lower frequencies, so this is not possible in practice. Do you have to reverse the polarity? No. But 9 times out of 10, it's a much better starting point, and will in general, cause much less phase issues. Just as a note, when using two mics on one source, phase issues are impossible to eliminate. Especially when they are a spaced pair. You just have to try and optimize the phase relationship between the two mics.
