P
pure.fusion
Hi all,
I've been mic'ing the guitar cab up close with a SM57 with "ok" results. Recently I've been trying to capture some of the room with a condenser mic with crap results. The room actually sounds pretty good, so I think the problem is the (cheap) condenser mic I'm using. It does capture the room and when I mix it in with the SM57 (and make sure the phase issues are minimised) it does add a natural space to the sound but it also adds something ugly to the signal (probably an EQ issue); so much so that I tend not to mix too much in as a result.
Should I just stop wasting time here, use a single SM57 to get that dry up-close direct sound and apply a small room reverb to mimic that natural room ambience? I guess what I'm asking is, it's effectively the same thing right?
I'm guessing that the only alternative is to try another mic as the room mic.
Cheers,
FM
Cheers,
FM
