M
Mistral
RyosaMusic
Well, that's what I read.Myriad_Rocker said:The sound files in BFD are proprietary? Uh, that's a big no. They are all in .WAV format.
sethbrand_12 said:5. Now the fun and long part...I will split the midi notes by choosing spit notes or whatever it is called in pro tools, and this will put each individual drum on its own midi channel.
This takes some time, but gives you as many drum tracks of audio on individual channels for mixing, effects, etc. Its great!!!
Dumby said:Have the volume adjusted on your cymbals, snare and whatever before hand. That's what I had to do with my TD-3 and it's fine again for homerecording.
Congrats on the 2000th postRobert D said:The problem with that is that you really don't know what the right balance of things are going to be until you get into a mix. That's why with all aspects of recording, including things like how much compression to put on a vocal, you want to commit as little as possible at the tracking stage, and leave as much control as you can for the mixing stage.
"Fine for home recording" is a very relative benchmark, with some people doing very casual home productions, and some endevouring to do profesional quality productions. Indeed, there is professional work being done in home studios, and being commercially released. Even amoung hobbyists, there are different levels of , shall we say...obsession.![]()
sethbrand_12 said:Hey guys,
I have the TD-6 drum set and I use it to record my drums into pro tools m-powered using midi. I play my drums just like an acoustic kit instead of just programming them. Once I have them in pro tools on a midi track, I have a way of splitting up all the tracks using midi and then recording each midi track, sometimes as many as 10, as an audio track for individual mixing. This is how I do it.........
......This takes some time, but gives you as many drum tracks of audio on individual channels for mixing, effects, etc. Its great!!!
Here is a link to my myspace page. www.myspace.com/sethbrand12 I write and record my own music. On these two songs I am playing ALL of the instruments and singing, and the drums are recorded with my TD-6 set just as described above. Tell me what you think!!!
seth
Mistral said:splitting the midi notes to different tracks won't make any difference when it comes to mixing.. in fact it only makes things worse in most situations.. first of all you won't be able to easily see where each drum hit is in relation to each other when doing editing.. but furthermore, you still have to assign these notes to instruments.. now what are you going to do, make a different instance of whatever drum plugin you use and waste 5x the resources and probably crash your computer in the process..?? or map the channels all to a single plugin anyway - in either case you wouldn't end up with any more mixing control than you would have before.. ya see plugins like EZdrummer let you assign each midi note/drum sound to its own stereo output already.. Same thing with Addictive Drums, and many others I'm sure.
It's also worth mentioning that if you are adjusting "volume" levels on the midi channels themselves, you are making a big mistake.. all that does is add or subtract the midi velocity value for those notes, so it will choose a softer or louder sample, but you are changing the actual samples and the dynamics of how the piece is played by doing so.. so never do it this way. Unless of course that is your intent.
Mistral said:Well, that's what I read.
Dumby said:Which ever one you want. You can assign which ever sound you like to each pad, a cymbal can be a bass drum, it's whatever you want, I've seen a couple guys at a local music store put a TD3 and 6, and have the craziest kits. They're excellent drummers to begin with but you get the point.
mattkw80 said:Another question about Drums....
With the TD-6, you get 2 Toms, and 1 Crash.
If I wanted to subsitute 1 of the Toms for a second crash (by switching cables into the brain)..... which Tom would I keep..... ?
(I'm having trouble explaining myself here....)
If there is a "high" and "medium" and "low / floor tom" which one can I do without, if I'd rather have a second crash instead ?
mattkw80 said:For a second just forget that they are even Electric Drums...... if you are a drummer who only has 1 Tom, would you want it to be the Tom with the higher tone, or the Medium Tone ?
Dumby said:That's weird, I got two crashes and three toms, a five piece kinda deal with my TD3, and I added a double kick pedal...check out the pic of my set in the distance on my soundclick
Dumby said:If I want a latin flavor and there's flamenco's blaring, I want a high tom. If I'm playing a Sabbath cover and I can only have one tom, the floor tom. Pick the tom you need according to the color of the song. That's the best way to decide, besides you don't have to be restricted to only one in your situation.
