Roland FA-06 to DAW on computer
  • Thread starter Thread starter frankerector
F
frankerector
Can I use the vocal guitar input and have it go to my computer DAW?
I'm just trying to use that rather then buying a usb audio interface.....
Will it work?
Thanks.........
Frank
Will it work?
Thanks.........
Frank
Bugger! I have just spent 5 mins reading the FA 08 manual! Still, IF the O6 has a jack labelled "mic" AND the kbd can record audio to a PC via USB, it all should work..But.
Any 1/2 decent microphone will be on XLR and unbalanced. You can buy XLR to 1/4" jack converters for around $20 and these also have a stepup transformer in them. This useful because the transformer unbalances the mic and gives 3x (10dB+) or more "free" signal lift and that IS useful because I doubt that mic input has a brilliant gain/noise performance.
You also need to get the drivers from Roland for your PC op system and if it is W10 you might have a problem there?
You cannot of course use a capacitor mic unless it has battery power or you also buy a phantom power supply*...Getting messy now? I have to say a interface is a much better long term solution all round and IF you go the AI route be sure to get one with MIDI DIN ports.
*Caveat VERY bloody Emptor on these! Lot of cheap, underpowered ***t about.
Hosa MIT-435 XLR3F to 1/4 inch TS Impedance Transformer: Amazon.co.uk: Musical Instruments
I think I’m gonna get the Presonus. It has free software too.
Which model? Presonus have a very good name and just because they don't get mentioned as often as the F'rites, Steinies and Tassies, does not mean they are in any way inferior.
Thanks Dave........
I just bought Presonus Professional and next week I'll get the audio interface.....
It should hopefully be a decent system...........
Frank
I wound up hating Presonus Pre.......
I downloaded the trial for Reaper and love it......
I have tons to learn on it but I've had a great time with it so far.......
Reaper and Presonus Audiobox 96.......
So much fun....
Reaper = win
Audio box = win
That is a good combination and should serve you well.
