Right On Bob!
  • Thread starter Thread starter SteveMac
Lt Bob,
It's good to talk about this stuff . Until I discovered this forum I so rarely got a chance to.
CD Convenience for sure. But because it's convenient, and less prone to wear, dirt etc doesnt say anything either way about its quality. It means it's more convenient, that's all.
The cassette too was convenient, far more so than the open reel. And in that case it WAS weaker in sound quality than open reel,(all other things being equal) but that was because it was a very cut down version of open reel, using only a fraction of the tape.
I didnt say anything about the quality of the turntable, preamp etc but totally agree it makes a difference, sometimes a huge difference. As a kid our first family turntable was a wind up Columbia Grafonola, all mechanical for 78's, from the 1920's I guess. Then the family graduated to a crappy BSR changer with ceramic cartridge with really cheap amp and speakers. So I grew up listening to crap equipment but also got lots of listening enjoyment from both. And while I dont currently own a really top notch turntable, I've heard them and agree they sound pretty good.
No, noise isnt the only factor in good sound and I didnt say it was. It was you who mentioned the possible need for 20 bits, implying that 16 bit, which is quieter than the best vinyl setup, was too noisy! You said it, not me! You seemed to be implying that the noise on the best vinyl is poor.
Does CD of itself "cut off 'verb tails"? I know without a doubt that some CD reissues do just that and it drives me crazy too. But what is the cause of that. I thought it was due to the addition of denoising or gating at the remastering stage so as to make older tape masters seem to have less hiss and so sound more "modern" and in keeping with quieter noise floors on modern recordings. "Cleaning up" old tapes and vinyls seems to have been promoted as some sort of miracle tool but the reality is, normally you can only reduce residual noise on any recording by also removing some of the ambience and room reverb. That's why I'm so reluctant to use it. But that's a human production choice and as far as I know has nothing to do with the Redbook CD format.
"analog lets it (the ambience and reverb) disappear into the noise floor". I noted you said analog, not just vinyl. Do you mean that this is part and parcel of the digital problem or that higher bit rates would fix this? And which noise floor are we talking about? The actual performance's noise floor before it even gets into the recorder, whether digital or analog, or the noise floor of the end product we play at home? Even on a 16 bit CD, I would expect the noise floor from the actual program and its ambience and reverb, would normally be somewhat above the CD's own digital noise floor. If that were the case, to expect the ambience to disappear into the DIGITAL noise floor would be unrealistic. You would hear a reverb tail and maybe some concert hall ambience, and then relative silence. Turn up the volume and yes you would now hear digital noise (or whatever was the noisiest part of the playback system) but the concert hall ambience cannot disappear into a noise floor in the sense of becoming MASKED by it. The reverse would be true, if anything. The ambience and reverb tails would mask the digital noise, if indeed it needed to be masked, in that it was audible without the ambience/reverb present. You can only mask a sound with a louder sound it that first sound was audible in the first place.
In any case, if it were true that CD audio did downwardly expand quiet passages, it should be measurable both with equipment, showing level mismatching at certain points, and apparent to listeners in double blind listening tests- even casual listening tests. Yes, our ears ought to be able to pick it. What do others think on this?
Read my earlier post where I object to just that sort of ham fisted attempts to "clean up" old recordings. I think most of us dont mind a bit of tape hiss or surface noise so long as the recording is overall clean and true. Less is more when it comes to fiddling with classic recordings.
When I first listened to CD's I was all at sea with setting volume levels. I was used to listening to the beginning tape hiss or the vinyl surface noise and that gave me a cue as to how loud to set the gain. With CD's the noise floor was so much lower I ended up turning the gain up way too high and when the music started it just about blew the speakers and me out of the room.
But again, having a much lower noise floor doesnt prove that it cuts the reverb tails. It proves that it has a lower noise floor. When I make a good quality CD copy of a good quality analog source, I play the CD back and the reverb tails sound the same as they did when I played the analog. The tape hiss or surface noise is where it was before. And thats what I'd expect.
To my ears aggressive mp3 coding really does cut off reverb trails and often a lot more besides and again I hate it for that reason. On the other hand, moderate, tasteful mp3 compression is useful, even though in certain professional archiving circles, it's regarded almost as the enemy. This must be an audiophile obsession only. Most of us happily watch DVD movies. How many of us refuse to watch them because of the quite severe compression of the video?
As to the extended supersonic response, and its effect on our perception I admit I cant judge from personal experience. I've never done one of those A/B listening tests so I only mentioned about the stresses that pressing the disc to those limits can cause. A related question that you or somebody else might be able to answer for me is how well those quadraphonic records from the 70's lasted compared to normal stereo issues. I know there were a few different formats. But I know from analog tape experience that you dont usually get anything for nothing. Boosting highs raises the signal above the noise but also reduces your headroom. Adding a quadraphonic carrier signal would have eaten into the the high frequency headroom, I would have thought. It's all additive.
And because the disc is spinning at constant rotation, not constant stylus speed, the inner grooves are bound to be of poorer quality to the outers and will really struggle with high volume high frequencies. 45khz? Usable? On the inner grooves? Is this in theory or in practice?
Dont misunderstand. I started out on 78's at the age of 5 and progressed to vinyl, first on cheap players and then on better ones, though probably not nearly as good as your machine. I have read some of the history of the whole disc cutting process in my audio cyclopedia , and at the Vintage Wireless and Gramophone Club I belong to, they recently showed a video of the incredible technology and care that went into disc cutting and duplication. An awesome feat in my view. A really mature technology by the 80's. BTW I still have all my vinyls and play them, but not before the ritual of careful handling and stylus and disc cleaning. Like you, I value my vinyl collection.
Best wishes, Tim
Beck(Tim),
OK, at what level below 0VU does the distortion begin? You want to put a red line at the bottom of the graph as well as at the top. Where should it be?
I want to know so I dont cross it. Put another way, what is the effective dynamic range of a CD before it starts distorting at low levels?
I dont claim to be an expert on low level distortion in Redbook CD's because I'd never encountered it. I guess I've been naive enough to think a bit number was simply a bit number and that since human hearing is more sensitive to level changes at lower levels that at higher ones, they would have designed the CD standard with that in mind, giving finer gradations at the lower levels than at the highs. But it's not really my area.
Over to you.
Tim
Tim Gillett said:
Lt Bob,
Misunderstanding there ...... I was talking about dynamic range .... not noise. And the 20 bit figure as being sufficient is a quote from the technical director of Meridian Audio UK. An opinion to be sure but an informed one.
And I'm not arguing anything ...... I don't care. I really don't. :)
I was just sharing what I feel like I hear ...... that's all. You're certainly free to believe as you wish and I'm not trying to convince you otherwise ....... I'm really not ....... just sharing thoughts, that's all .... don't care .. etc. etc..
:D
But in the end it comes down to what you hear regardless of any measurements you want to throw out there. I trust my ears more than yours or anyone elses 'cause I know what they do. I've really made a living off my ears and continue to do so.
So for me after 42 years of playing ... 35 years of recording and 30 years of piano tuning I think it's understandable that I'm gonna go by what I hear and I hear what I hear.
Lt Bob,
That's fine. We were both just saying what we thought. I found the Meridian article and hope to plough through it. Not an easy read. Like going back to school!
Looks like you play the sax. I'm a bass guitarist, when we can get a gig that is.
Cheers Tim
I have to vouch for Lt Bobs convienance theory. Though I know alot of people switched to CD because they really loved it. If it ever went back to vinyl there'd be alot of angry people. Anyway like I said before, I know myself and other people I know didn't like CDs we all thought analog sounded alot better. I actually had CDs before I even had a player this was in 1991 and they where Beatle rarities so I had to get a player to hear them. From there it was all down hill. :D
Tim Gillett said:
Lt Bob,
Cheers Tim
Cool ... yeah I play sax but actually bass and git too.
It helps pay the bills ...... if I do 6 gigs in a week I might play with 6 different bands ..... git with one .... bass with another .... sax on most. What part of the country are you in?
:D:D
:D:D
Lt Bob,
I'm from the land down under, Australia. Would love to get to the US one day.
I'd better start saving by playing more gigs! I've been in dance band for about 9 years. We've had some great times just rehearsing and then doing the gigs. There's nothin' like makin' music, hey.
Tim.
Tim Gillett said:
Beck(Tim),
...You want to put a red line at the bottom of the graph as well as at the top. Where should it be?
I'd say: right at "0" :D :D :D
here:
Aaah, another from the West Island. ;) There's a few of you Aussies floating around here, not too many other Kiwi's though. :eek:
Yes except I'm at the almost most westerly point of that island! You're probably closer to the USA than to me!
Regards, Tim.
here:
And I think maybe you speak for a lot of people on the analog only thread. But at least you're happy... that's what counts in the end... ;)
Tim Gillett said:
... at least you're happy... ;)
I'm not. I would be if the digital audio meters were corrected. But it ain't gonna happen, so... - so, I'm not :(
:D
:D
Let me give you some hope then. Look at it this way. The average classical music lover is not stupid. They know the real thing from attending live symphony concerts with real acoustic instruments. They know best of all that they've been putting up with Redbook CD crap for 24 years. Just ask them. They tell me all the time.
Someone should take a mainstream classical music CD, copy it carefully to open reel 2 track and then burn a CD-R from that. Then play it to selected classical music lovers and concert goers. The improvement in sound quality will simply blow their socks off! After 24 years in the audio sound quality wilderness, they'll start to hear concert hall ambience again in their own homes. And best of all, the ambience and reverb will tail off into that holiest of holy sound, analog tape hiss. Then the record companies will be pressured to use that intermediate step themselves on every classical CD issue, or reissue.
If the companies refuse, there will be huge public outcry. People will simply demand to be able to do the copying to open reel, and then burning back to Redbook, themselves, or pay others to do it for their entire CD collections. All of a sudden there will be nationwide demand for good quality open reel machines and tapes. The old factories will be reopened and production started with a vengeance. The Quantegy debacle will seem to have been a minor blip. Soon there will be new pro quality open reels and tapes on the market once again! As a bonus, the price of good used open reel 2 tracks will soar.
Think of the employment created! The economy will lift. The drought will break. Global warming will start to retreat and crime in the streets will recede. Best of all, grown up men will get in touch with their feminine side and learn to cry. Mental health problems will be a thing of the past.
Hey, this is really uplifting stuff. I'm almost starting to believe it myself... Have faith, brothers.
Tim
I don't know about that. Some of them well may be. I assume the majority of them are not... I would not assume so about average faithful CD-music lovers, though... but again, what do I know.
I don't know what they know, because I never asked nor they've come to me to tell for what ever reason they may wish to do so...
But I do know the real thing from attending live symphony concerts with real acoustic instruments and from other activities as well and I've been putting up with Redbook CD crap for 20 or so years. A lot of them are real crap, but some are pretty damn good sounding recordings... I also have noticed that most of classical CDs that I happen to like were originally recorded without digital technology involved. How exactly the original recording were transfered to CD-format - I have no clue, because never cared to find out. Some classical CDs with older recordings on them in fact ARE REAL crap, and I mean not just bad, BUT rather painfully horrendous. I have huge classical and orchestral vinil records and overall I'd say those records are irreplaceable. That's what I DO know.
Now, Tim... your sarcastic parody is kind of fun, but I am not sure what exactly your main point is. I can guess, ... but I don't want to assume something I am not sure about.
Now, practically, from my experience, when simply re-recording from CD to R-to-R and playing back the tape comparing to the original CD - the somewhat ear pleasing effect DOES take place. What ever it is from technical point - I don't know and personally don't have brains nor whish to seriouselly get into it. It has to be a subjective matter also. well, I never ever re-transfered from R-to-R back to CD-R ... so ..I have no idea about that one.
Tim Gillett said:
Then the record companies will be...
frankly, I don't give a lonely miserable drop of sh*t about them and what they may or may not or will or will not decide to do or do ... not in respect to a serious matter , not in respect to a
satiric essay...
Tim Gillett said:
Let me give you some hope then...
Give it to someone who asks you for it ;)
/later
oh, one more thing, Sir....
when writing a satiric piece, the very last line of the culmination may be and most likely will be taken as the expression of the essence of the entire writing, so the line "Mental health problems will be a thing of the past." in conjunction with heavy sarcastic flavor of the entire essay most likely will be read as: "My satire is directed against a point of view of Mentally Challenged"...
Well done, Tim. :D
Do your hear any applause yet.? Here they come:
"Clap-clap."
Yes it was a satire, and like much satire, not directed at any one person or group but making a few general points, in the spirit of an often humourous and tongue in cheek tone that is found on this and I guess any number of other forums on the net.
But I thought you, Dr. Zee might appreciate it because you can write in a similar style which I enjoy and it actually gave me the idea in the first place.
Being a sort of "tech head" I can sometimes get a bit too technical myself.
Life is not always a bunch of cherries and as for many other folk, humour and a good laugh is often what helps to keep me sane, or whatever modicum I possess of it.
Regards, and no offence meant. Tim
Tim
Hee haw... I've heard something almost exactly like that before, in the early days of the digital revolution about what "CD quality" would do for the world. :D
Tim Gillett said:
But I thought you, Dr. Zee might appreciate it ...Tim
...and that's the case, that's why I re-read your post seven and a half times or so :D :D :D
...no offence meant...
offence?!!! heh heh I live in the deep stone cave... nothing offends me... :p , but I have that huge terrible wall-to-wall resonance in here... so I respond in a rather very bouncy manner.
And, just keep in mind, that this community if full of sensitive individuals with rich imagination... artists that is :D , so you have to be careful... well, that's in case if being a nice guy is more important for you than the matters. I think Bob (the one in the title of this thread) knows allot about it ;).
Speaking of nice people, is(was) Bob ever seen as a Nice Guy? hmmmmm , what do you think?
/respects
Beck said:
I've heard something almost exactly like that before, in the early days of the digital revolution... :D
...which was NOT published HERE :D
Beck (Tim),
I find it interesting. If there was one person I was specially addressing in my little satire it wasnt Lt Bob or Dr Zee but you, who still hasnt responded to my query as to where you would have put your second red line on the CD recorder bargraph. Whose idea was the extra red line? Yours. So why dont you back yourself?
Now when you finally make a contribution, you avoid all the audio issues I make and selectively quote the purely non-audio bit of satire right at the end of my piece.
I'm not an apologist for the early promoters of CD's and home CD players. We're talking about playback of Redbook CD's today, not 24 years ago.
When you offered earlier in this thread that you go to the trouble of recording all your CD's to reel to reel and then burn fresh CD's from that, I thought surely it was April 1. (April Fool's day in my neck of the woods)
Really Tim, were you serious or just having a lend of us?
I dont mind either way. I like a good joke.
Tim
