kip4
let us know when you post up a recording please. I'm glad you liked it.
First rule of ribbon club tell everyone what they are missing.
Ummm, stil £89 here but everywhere else is £149![]()
Yeah, i think the vast majority of home recordists still fear ribbons as 1) they are super fragile and 2) you need a half decent preamp to get clean recordings with one. Plus they tend be much less versatile than your average LDC and many HR's just want a couple of "do-it-all" mics.
It's not in stock there. I got one of the only ones left and it was £140 but still super chuffed!
after posting i did then see the big "available on request" rather than in stock msg
Not true at all for the SE X1R and a lot of the modern ribbons![]()
It's part of the reason that a lot of the cheaper ribbons have sooooooo much extra internal blast filtering/wire mesh; they know their market and don't want returns so do everything they can to protect the ribbon element. And, again, by comparison newer ribbon mics probably need less gain than older models thanks in part to up dated electronics etc, but apart from on the loudest of sources, it's still not uncommon to see preamps cranked to get decent working levels. Which bit, the being fragile or needing a shed load of clean gain? Granted modern ribbons are more robust than older models but a lot of people are now so used to using an SM58 as a hammer or a C1000 as a door wedge that, by comparison, ribbon mics are still fragile. You can still snap a ribbon by blowing on it, moving it around without a cover, or drop kicking it. Tbf when i first got a ribbon mic i was petrified of breaking it, but the more i used it the more i realised that it wasn't as fragile as i thought it was, but i'm still never gonna use it to drive in nailsIt's part of the reason that a lot of the cheaper ribbons have sooooooo much extra internal blast filtering/wire mesh; they know their market and don't want returns so do everything they can to protect the ribbon element. And, again, by comparison newer ribbon mics probably need less gain than older models thanks in part to up dated electronics etc, but apart from on the loudest of sources, it's still not uncommon to see preamps cranked to get decent working levels.
but yeah, I guess it depends if you want to use it as a door wedge, or not.
Tbf one of the many reasons i still have my eyes on the sE X1R is it's "borrowed" technology from the Voodoo range which are awesome mics, and the extended high frequencies and updated electronics should make it out perform most ribbon mic's in the same price range
Ribbon mics are fragile, no question. So you don't lend them to anyone!
Modern ribbons have transformers with quite high step-up ratios, so high preamp gain is not always needed. My DIYAC RM-5 ribbons, for example, use Cinemag transformers with a 1:37 ratio.
I guess it depends if you want to use it as a door wedge, or not.![]()
And yes, that's what attracted me to it and actually, I tried it out, along with the VR1 and actually preferred the X1R - for the flute, anyway!
The fragility lies, not in the bodies which are usually very robust, but in the ribbons which are a crinkled strip of foil just a few microns thick. These ribbons are fastened in place under a slight degree of tension which strongly influences their audio response.
Dropping the mic, shaking it vigorously, or puffing air into the ribbon can irreversibly stretch the ribbon and alter the sound.
Just treat the mic with respect. Some users insist that ribbon mics should be stored upright so that the ribbons do not lie in a sustained bow.
One of the members here, Xaudia (Stewart) is an expert in ribbon microphone repair and restoration. Perhaps he will chime in with some thoughts.
Paul
Oh, and already bought a pop shield as well, just in case.
Cool I always use a pop filter even infront of a guitar amp for my ribbon. its surprising how much air a speaker will push.
I also almost punched my singer recently for blowing on my ribbon mic after i told him not to (granted it had a heavy duty pop shield in front of it so there wasn't a huge risk but still, what a knob!). I then realised he's a 6' 4" northern built like a small tank/rugby player, whereas i'm a 5' 6" southern built like a dungeon master, so instead i just did my best "disappointed dad" impression. He got the hint.
Next time, disappointed dad might just need to follow up with a docked allowance and 9pm curfew
Thinking about Rugby, our local boys received a bit of a butt-whooping from the touring British and Irish Lions last night. <<grumble, mutter>> Never fun losing to the Poms!
Paul
