Rewire issue
  • Thread starter Thread starter mjt
M
mjt
Hello,
Hi all! I am new here. I have been trying to solve this issue for all day with no luck. Have searched the forums and everywhere else.
1) Successfully got reason rewired to Sonar.
2) In Reason created 14:2 mixer then created a NNXT instrument and a nn19 instrument.
3)In sonar setup first track for recording as follows:
INPUT- USB Audio Device OMNI (m audio keystation 88es, note that all midi inputs in Reason preferences dialog are set to NO midi Input and output. In the keyboards/controllers dialog I have DEselected the keyboard controller).
OUTPUT-2-Reason
CH- 4:NN-XT 1 (RW bus 5)
BANK- bank (nnxt is an option. tried that did not change anything.)
PATCH- none
All good so far. press key I hear it. record I see midi data and hear it. playback I hear it as I should.
PROBLEM: setup 2nd rewire track for 2nd reason instrument same as above except for CH I selected NN19 (RW bus 5). Plays and sounds as it should BUT WHEN I RECORD THE PLAYBACK OF THE FIRST TRACK I RECORDED SOUNDS AS IF IT IS NOT PLAYING ALL THE NOTES. IT PLAYS JUST A COUPLE AND SUSTAINS THEM.
Has anyone run into this same problem?
