david winter
Member
Hi,
My B77 is currently back to service so I put a PR99 (read only) to play my tapes in the mantime. The problem is, the outputs are XLR balanced type, and the machine is to be connected to a normal amplifier with RCA plugs.
I currently connected the headphone output to the amplifier input and set the headphone volume to the good position. In the future I'd prefer using the XLR output, but how do you convert to unbalanced ? Do you simply use two of the three pins, or do you have to use a matching transformer ?
Thanks,
David.
Thanks,
David.
