Here is a copy of an email I just posted to the Timeworks tech support guy who finally answered after about 3 weeks.
I have just finished running numerous tests to try to determine the root of the problem. What I have found is that
ReverbX runs fine on all my systems, under either win2K or Win98, if the sample rate is set to 44.1KHz. If I set the sample rate is raised to 48KHz or higher, the more complex algorithms - Hall, Room, and Chamber - cease to work - crashing the program if selected. This happens whether the OS is win98 or win2K, so my initial belief that the problem is OS related, is wrong.
I have tested on the following systems :
Win 98 + win2K
AMD 1.2 GB Tunderbird
256MB PC133 RAM
Epox motherboard w/ via chipset
Both MAudio Delta 66, and onboard sound.
Win98 + win2K
P3 733
256MB PC133 RAM
Asus Motherboard
MAudio Delta 66
Win2K and WinXP
Dual AMD MP 1600
Tyan Motherboard
512MB 2400 DDR
MAudio Delta 1010
Mixing software on all - Cakewalk Sonar, Ntrack 2.3 + 3.0
I suppose a common element here is
the MAudio delta series soundcard. However, I did get the same result with the Epox onboard sound. My previous belief that the problem was OS related was due to the fact that in win98 I was always using the 44.1K sample rate.
Considering the diversity of systems on which I have encountered this problem, I cannot believe that I am the only one experiencing it.
Ben
